Jagg oil cooler system install problem
Received 4,317 Likes
Why don't you just buy the right oil cooler? Or is the problem a sandwich plate that goes on the oil filter spinon? Harely's don't need that. Just get an oil cooler with a built in thermostat or a separate thermostat and plumb it all in the line between the oil filter and the tank, like God intended. Or in Texas, don't even bother with the thermostat, as you'll only need it for that second week in February when it is "winter." Put a cover over the cooler that week and you're done.
That makes a hell of a lot more sense than this https://en.wikipedia.org/wiki/Spinon
Schex (07-22-2019)
Wikipedia. The first place I go when I want to know what an idiot thinks they know about any subject.
Anyway, you're trying to put an oil cooler on your bike, right? Why doesn't it fit? Are you trying to put something on the original oil filter SPIN THE F ON mounting point? Like what is called a "sandwich plate"? And the sandwich plate interferes with something? 'Cause otherwise I don't see what your problem is. Put new hoses on it and don't worry about it.
Yes,
Because of where the rear brake reservoir is the adapter plate that attaches to the filter mount (it actually raises the filter about an inch or two) raises the oil filter too much to fit between the break reservoir and the front jug.
When I get around to it I'm gonna relocate the rear brake reservoir so that it's no longer in the way.
That's the one I would have to delete to simply pipe in the cooler without using the adapter.
Then you might try a different sandwich plate:
https://www.summitracing.com/search/...ich%20Adapters
I ended up making a couple brackets to move the reservoir.
Here is how it ended up
Dan89FLSTC (08-27-2019)
