Not Another Crankcase Breather Oil Problem after all
RE: Not Another Crankcase Breather Oil Problem after all
Monday morning update. I tightened down the bolts on the lifter blocks and it appears to have worked, but I was only able to warm the bike up in the driveway, I haven't road tested it yet. Damn these storms. Each bolt needed about a quarter turn.
ORIGINAL: DeJavu
It's great when you find an easy fix, hope that was it. Sure saves a lot of wrenching if it is the solution. Unfortunately you lose the opportunity of tearing it all apart and gaining experience[sm=smiley20.gif]!
The good news is that during all of this, I found the high idle adjustment, so now I can let the bike warm up on its own instead of having to babysit the throttle constantly.
Now as soon as I get the turn signals to blink without holding down the button, I will have fixed all of the things the P.O. messed up.
ORIGINAL: uesque
On my 86, you to have to hold down the button to get the turn signal. My wife's 87 883 also. I don't know what year they went to the next one, which was a turn signal on/off switch where you push once to turn on and once to turn off. Then came the smart ones after that.
