Andrews EV-46 cam
Old 03-13-2008, 02:19 PM
MEATCLUB's Avatar
MEATCLUB
MEATCLUB is offline
Default RE: Andrews EV-46 cam
True its one of the the lighter bikes, But apon futher review of the scale in the bathroom tellin me Im 350lbs and the wifey is bout abuck 30. I have went with the 27 grind from Andrews. S&S blocks, taps, and rods on the way. Thanx for all the help. Respects to The Warlock Nation.
Old 03-14-2008, 08:38 PM
JBaker421's Avatar
JBaker421
JBaker421 is offline
Big Kahuna HDF Member
ORIGINAL: MEATCLUB
You won't be sorry. Great puller, noticeably much more power and nice lope at idle.
Good choice.
Old 09-29-2012, 10:49 PM
neverstuck's Avatar
neverstuck
neverstuck is offline
I literally just did a full topend on my 84 fxst. heres what I have , finished today. ev-27, ported and polished heads, and 9.75-1 .040 over Kieth blacks.. I havent had a chance to get the timing and carb dialed in ( S&S super e) but I took her for a small shakedown romp this afternoon..I noticed Im feeling very flat on the bottom end, once I hit about 2000-2300 rpm its pulling alot harder..I def have to set the timing tomorrow...Im 300 pounds, and though my bike has no accessories, Im figuring about 700 pounds for the bike...I also have a pipes issue , 2" drags (bad choice over 10 years ago, with torque cones...I wish someone made a good 2 into 1 for a kick and electric evo..I think Im at the max for the cam too..once shes broken in ,Ill get her up on the dyno for some serious tuning and get some numbers...
Old 09-30-2012, 02:00 AM
badcooky's Avatar
badcooky
badcooky is offline
Any Evo i've owned has ended up with an EV46 in it .
I like how it's just plug and play too.
Old 02-06-2020, 03:18 PM
Enrique Durazo's Avatar
Enrique Durazo
Enrique Durazo is offline
Stage III
Good afternoon to all members, I have a fatboy 98, evo engine, without any modification to the engine, I'm curious to install a cam, I just want to develop some more power, what would be recommended? Greetings from México
Old 02-06-2020, 03:52 PM
K. Lindberg's Avatar
K. Lindberg
K. Lindberg is offline
I’m no expert.
However... if Your motor have no changes done to it what so ever, You could change your Air cleaner for something less restrictive, a good set of slip-on mufflers, some fiddling with the carb and see if that is enough for you.
Old 02-06-2020, 04:07 PM
LQQK_OUT's Avatar
LQQK_OUT
LQQK_OUT is offline
Received 1,563 Likes on 1,082 Posts
Take a look at the Andrews EV-27
http://www.nightrider.com/biketech/hdstage2.htm
Old 02-07-2020, 03:22 PM
mr-stabby's Avatar
mr-stabby
mr-stabby is offline
had the ev-46 in my fxr with stock compression, hsr 42 ,big sucker and a supertrapp 2-1 it was good from 3000rpm on , i picked up a ev-27 cheap and i love it the bike rips from just below 2000rpm to just before the 6000 rev limit ,, bike is more usable now and a dam sight more fun to ride
Old 02-16-2020, 07:35 PM
Anthony Paul's Avatar
Anthony Paul
Anthony Paul is offline
EV-46 ftw. I put one in a few years ago and I really like it. Of Course I did a whole lot of Mods to the bike. However it really moves. Never any issues with the install and It really loves the higher RPM range as well. So I re geared it and slapped a 6 speed in it and whole lot more.
tpb857
Shovelhead
29
02-20-2016 12:49 PM
troop
Exhaust System Topics
03-23-2010 08:13 AM
gargoyle
03-07-2008 08:09 PM
cmcsns
01-30-2008 04:06 PM
mav7500
Shovelhead
12-25-2007 02:31 AM
Quick Reply: Andrews EV-46 cam
