strange problem today - any ideas
Without having a schematic in front of me, I can't pinpoint it but your problem should be in your power supply to your ignition switch as everyone mentioned or your connection at the switch but I would head towards that relay because heat(switched on) would make a weak relay shut down intermittantly. 2 different circuits are acting up ecm power and starter solenoid power which both are controled by the ignition switch.
And Go Bucks!
And Go Bucks!
For some odd reason, my 60 year old brain has unearthed a foggy notion: Didn't The MoCo have problems with the ignition switches in the early/mid 90's. Seem to recall some issues with fires, etc.
Or it could be one of those damn 70's brain locks I seem to be getting more and more often.....
I've had the same type of problem twice on my '94.. Switch on, lights on, nuthin when you push the button.. Both times it has been the cheap *** "run" switch/button... The last time (last summer), I decided to cut the harness at the neck and splice the wire together. I now have no "run" or "start" button opperation, but with the manual button on the starter, my bike has never failed to start and continue running since..
In diagnosing it, you can rock the run switch several times, fairly roughly to see if it makes a difference.. Obviously, it would also be very helpfull to check the voltage to and through the switches..
I don't know if Bertha's switch was ever replaced - but it seems to work fine. I've never had the issues described in this thread though...
