Anybody got a pre 1988 EVO 1340 wiring diagram? Mine is custom built so wiring should be pretty close to FXRs. I have no flasher wired in and LO/HI Beam is actually HI/HI. Thanks.
If you find a wiring diagram for your bike here's a tip. Take it to a good copy center and have it enlarged along with the legend. Then have it laminated, that way you can prop it up and read it without walking away from the bike. Hope this helps.
Did that with my piglet(Sportster). The bike is an FXR Custom built from frame up. Has an 88 FXR 1340cc and 5spd tranny so I am guessing the wiring would be for the same. I am used to the majority of the harness being in the headlight but this one appears to be around the battery. May have to trace and draw it myself.
