Backfiring when starting
I recently purchased a 98 fatboy with 9000 miles. Stock motor, mikuni 42, stock jets, screamin eagle ignition module #32630-96, screamin eagle coil #31647-97, stock cam sensor, and vance & hines pipes long shots or big shots. When trying to start, I pull the choke, and attempt to start. It acts like it wants to but never does. If I give it any throttle, it backfires very loudly and still does not start. It will eventually start if I crank the throttle a lot and ignore the backfiring. When it finally starts and warms up, it runs well. I am trying to test the coil at this time. Does anyone think this may be an electrical or fuel issue? Any suggestions would be greatly appreciated.
Thanks
Don M
Thanks
Don M
This could be a couple of problems, 1st I would get it running and check the ignition timing, if that is correct move on to the ignition module, is that a single fire style or a dual fire, verify that the coil corresponds with the module i.e single fire coil with a single fire module. If all checks out then move on to the carb, you say it has stock jets what do you mean by this? The jet numbers on a CV Keihn are not the same on a Mikuni. When you get that far post the jet sizes for us, I am running a similar set up as you so I can tell you what I am running for a carb set up that will get you close depending on elevation.
Thanks for your suggestions. I checked the numbers on the ignition module and seems to be a recommended part. It is dual fire to the best of my knowledge. The coil seems to be hard to find information on. The jets are needle jet 97 with the clip in the 2nd posistion. The main jet 160 pilot jet 20. The choke cable is a Harley cable with the spring and plunger being Mikuni. The bike is only backfiring thru exhaust pipes. I had the bike running with timing slowed pipes became very hot. I checked the ohms on coil primary was 2.8 and secondary was 19000. I read 2-3 was good on primary and 10-13 for secondary. Don't know much about this. Could it be firing at the wrong time would that be caused by ignition module. I don't know how to test that.
Thanks
Thanks
Backfiring through pipes means the engine is being flooded with fuel. Try starting it without choke, just to check how it goes. I had similar problem a year ago with stock CV carb. Float valve was faulty giving too much fuel, when I pulled choke out it would not start, just backfirig through pipes.
I took the carb off today and run cleaner thru it all, seems there might have been some junk in the tube that allows the enrichner to draw the fuel up out of the bowl. I have tried starting it several times since and is starting good, I will see tomorrow after it sits all night. I am going to put an ev27 in it so if any one is running a set up like this I would be curious to know what jets you are running.
Thanks for all the help. Don
shuvl
10-04-2013 03:52 AM
magnum629c
01-22-2013 06:02 PM
