crankcase vent hose allowing oil into air cleaner
I have a '91 FXR stock EVO. I am getting A LOT of oil blowing back from crankcase to the air cleaner element through the crankcase ventilation hose. I assume this is due to a common problem called "sumping" whereby a check valve does not function properly and allows oil to drain down from the oil tank and fill the crankcase when the bike is sitting for a long time (as in over the winter). There is some sort of canister element installed inline on the vent hose between the breather and the crankcase. It looks like it might be an aftermarket regulator to prevent that from happening? At first I thought it was some sort of PCV valve like on a car, but there are no moving parts, just two canister halves, inside is what looks like a diverter with five holes in it, so the oil has to
Do I just live with it or can it be corrected?
Steve D.
Minden NV
Steve D.
Minden NV
some guys just reroute the hose avoiding the aircleaner.There are also filters you can purchase.There are also complete kits with new chrome lines and a filter.I had that problem with my old 92 Ultra.take a look at these on Ebay: 130390726306 or, 320418908915
Hope this helps, just do a search for harley parts,crankcase vent.
Received 47,786 Likes
Steve D.
Minden NV
Steve D.
Minden NV
your breather inside your engine, driven by your cam shaft might also need replacing. A lot of them are plastic & when they wear down or get scratched, they can let some oil through. Easy job to replace! Best bet though is re route your breather line & add a breather filter to the end. Their less than $10.
Hatch.
Hatch.
You had better assume this is due to worn piston rings. The "cannister" is supposed to separate the oil from the air before it goes into the air cleaner. Removing it will make the problem worse.
Most bikes will sump if their left to sit but once started, the oil returns to the bag quickly! There is still oil blasting around in the case when the bike is running which is why the plastic breather is inside. It is timed with the cam shaft to open & close through the different strokes to help relieve crank case pressures.
Hatch.
Hatch.
Hatch.
Hatch.
