Replace Sprocket Shaft Bearing Seal
SH*&%# wish I woulda read this before
on a road trip and the seal went on my *91 had to get someone else do the work and the ***** leaked into my primary all the way home.had to stop every 50 miles empty my primary and fill my bucket to get it home,what a F*%#@&n mess! took out the seal at home and it wasn't even installed flush and the case was scored by something or someone!! after doing some research i thought maybe the case was hooped so decided to spend the $$$ and just go for a 113 ultima. fun choice but expensive road trip.any ideas as far as fixing my scored case?
at least I will have a chance to build a bar hopper for my intown days!
First, I would try putting another seal in if the other seal wasn't in all the way. If the case is scored bad, anaerobic gasket seal may solve the issue, otherwise you're into JBWeld to fill the scored lines. You'll probably need to sand that out smooth again. Also use something to fill the screw holes for the stator wiring bracket since these are drilled all the way through per previous posts in this thread. I used anaerobic sealer here and this solved my issues completely.
Trnny vent hose pushing oil and air
What seal exactly please and is it costly to repair? Thanks
Greetings. First off, you probably should have started a new thread instead of hijacking this five year old thread.
For your leak, a vent tube is a vent tube. There should be some pressure in your tranny from the gears functioning and that tube is made to vent any pressure. Most of the time if you are puking oil out the vent tube, then you have overfilled the tranny/primary. Also note that on the Sportster, your tranny and primary use the same oil so if you overfilled your primary, you overfilled your tranny. Pull your clutch inspection cover and check how much oil is in there.
Just trying to get my bike right while I'm in chemo, so sorry if I don't follow protocol
