OIL Filter for 1999 fxr3
Big differences between the two filters is less restriction, lower filtration, and lack of Anti Drain Back Valve (ADBV) in the Evo. In use, the Evo filters oil between the engine and the tank and the TC filters between the tank and the engine. A filter with higher restriction like the Super Premium 5 on an Evo often causes some problems. Basic problem is too much oil in the crank (sumping). Oil out the breather, sluggish engine, smoking may result. The operator may or may not notice or may mis-diagnose the cause. The MoCo actually used to list the SP 5 filter as an “upgrade” to the Evo (maybe still do?) but experience says otherwise. Some restrictive automotive filters on an Evo can cause the same symptoms. Some automotive filters work fine and some are actually app’d for use on Evos by the manufacturer (3614 Champ Ecores and 51215 Wix for example).
You do what you want, but I'm sticking with EVO spec filters.
hey anyone one use the longer K&N
KN-173
I KNOW ONE GUY WHO RUNS IT ON HIS EVO another on his 96 Twin Cam .. humm ? IS IT OK FOR ETHER ENGINE?
Features & Benefits
http://www.knfilters.com/search/prod...x?Prod=KN-173C
K&N powersports oil filters are ‘TUV’ product endorsed and ‘TUV’ factory production monitored. Our filters contain a modern synthetic filter media, designed for ultimate flow with less pressure drop, yet engineered for outstanding filtration. K&N powersports ‘spin-on’ oil filters feature a heavy-duty metal can. Most of these have a 17mm nut affixed onto the end that allows for easy installation and removal. The 17mm nut is crossed-drilled so racers can safety wire the filter to their bike.
Part Number:KN-173CWeight:0.91 lbsAnti-Drain Back Valve:YesBy-Pass Valve:YesFiltering Material:High Flow Premium MediaGasket Material:Nitrile RubberNon Slip Grip:NoOil Filter Diameter (in):2.98Oil Filter Height (in):5.98Oil Filter Type:Spin-On/CanisterRemoval Nut:Yes
KN-173
Features & Benefits
- O/E replacement oil filters for most cars, trucks, SUVs, motorcycles, & ATVs
- 17mm exposed nut designed for easy oil filter removal
- Heavy duty construction for extreme conditions
- Resin-impregnated filter media traps 99% of harmful contaminants
- Anti-drainback valve (where applicable) eliminates dry starts, prevents oil from draining back into crankcase during engine shutdown
I lifted this quote from the link I gave in #5:
It is very tempting to look at other filters, but having read the K&N stuff I don't see anything that says they are OK for Evos, let alone Harleys. That other thread makes clear that Evos and TCs have different oiling systems, which is why they have different filters (if we ignore the 'experts' that is!).
For the little cash I might save I prefer to use branded filters. Having an S&S motor I use either S&S or Harley Evo filters.
ummm well ummm da gosh after readinng the last post i clicked around the K&N link and K&N Says the longer kn-173c is for the below harleys and gosh i think most of them are evos ?
now the 1999 fxr3 is an odd bike only about 800 made .. 1340 evo .. so unless its diffrent some how . i think i could run a kn-731c unless someone can come up with a reason why its difFrent from all the below evos it is made for ?
K&N KN-173C fits the following:
1998 HARLEY DAVIDSON FXDWG DYNA WIDE GLIDE 1314 - All1998 HARLEY DAVIDSON FXDS DYNA CONVERTIBLE 1340 - All1998 HARLEY DAVIDSON FXDL DYNA LOW RIDER 1314 - All1998 HARLEY DAVIDSON FXD DYNA SUPER GLIDE 1340 - All1997 HARLEY DAVIDSON FXDWG DYNA WIDE GLIDE 1314 - All1997 HARLEY DAVIDSON FXDS DYNA CONVERTIBLE 1340 - All1997 HARLEY DAVIDSON FXDL DYNA LOW RIDER 1314 - All1997 HARLEY DAVIDSON FXD DYNA SUPER GLIDE 1340 - All1996 HARLEY DAVIDSON FXDWG DYNA WIDE GLIDE 1314 - All1996 HARLEY DAVIDSON FXDS DYNA CONVERTIBLE 1340 - All1996 HARLEY DAVIDSON FXDL DYNA LOW RIDER 1314 - All1996 HARLEY DAVIDSON FXD DYNA SUPER GLIDE 1340 - All1995 HARLEY DAVIDSON FXDWG DYNA WIDE GLIDE 1314 - All1995 HARLEY DAVIDSON FXDL DYNA LOW RIDER 1314 - All1994 HARLEY DAVIDSON FXDWG DYNA WIDE GLIDE 1314 - All1994 HARLEY DAVIDSON FXDL DYNA LOW RIDER 1314 - All1993 HARLEY DAVIDSON FXDWG DYNA WIDE GLIDE 1314 - All1993 HARLEY DAVIDSON FXDL DYNA LOW RIDER 1314 - All1992 HARLEY DAVIDSON FXDC DYNA GLIDE CUSTOM 1340 - All1992 HARLEY DAVIDSON FXDB DYNA GLIDE DAYTONA 1340 - All1991 HARLEY DAVIDSON FXDB DYNA GLIDE STURGIS 1340 - All1982 HARLEY DAVIDSON FXB STURGIS 1340 - All1980 HARLEY DAVIDSON FXB STURGIS 1340 - All
