That bracket looks similar to the correct one....but it is not.
The bracket you need is plastic and has two small holes that screws go through in the back of the guage. I wish I had a part-number for it...but I do not.
Those are the correct ones for sure. They are really kinda cheaply made by Harley.....but they do the job. Make sure you get the screws also. The screws from your 1999 model won't work...I found that out really quick you have to get the ones designed for the new guage/bracket.
i know this thread is old but has anyone else done this swap? i have a 1999 ultra that has cable speedo that broken. but would like to keep it harley.
A broken cable is easy to fix! You may get away with replacing just the inner, although probably better to replace the entire cable, especially on an older bike.
its not the cable the speedometer its self broken was riding and it made noise and needle pegged out them broke off before i could get it stopped. they are obsolete through harley . and all the replacements i see are electronic.
It may be possible to repair it, I'm sure I've seen details of somewhere that does that. I suggest you start a new post, as posting in an old one like this hides your query away from a lot of members.
There are a couple of speedo repair shops that can fix it for you. It's going to be a lot cheaper and easier than trying to swap it. My Factoid database says:
