How do I remove the main bearing???
I am trying to replace the main crankshaft outer bearing and not sure exactly what is required to replace it? Do I have to use a special tool like the "JIMS" brand?
I am hoping this can be done with out splitting the case? Thanks in advance!!!
Hi markle and welcome to HDF from the UK. As Spanners says, the only way of getting out any of the crankshaft bearings is by dismantling the engine. They are the biggest and most important bearings in the motor and if one needs changing you should change both.
What mileage does your bike have and why do you want to change that one?
Thanks for the info, I was afraid that was gonna be the answer...its just that Lonestar is this weekend...and I really don't want to ride my Suzuki there :-(
The bearing seal on that side was leaking pretty bad but after some investigation it appears that it is only the seal b/c the is 0 endplay and the bushing had no grooving either so hopefully I can get away with a seal. The motor is actually an S&S super stocker w/15,000 on it. The HD seal should fit right? b/c that I can get installed by Thursday.
Received 4,317 Likes
