Carburetor Identification
Have a '94 Electra Glide that I bought at a dealer used. Since then my throttle cable has broken twice. It doesn't have the stock carb on it cuz the stock throttle cable didn't fit at all. I got an S&S cable from the dealer and still had to modify it to work. Is there an EASY way to identify what Make & Model of Carb I have on my bike without tearing it apart? I need to know cuz I now have to lean out my carb after making my exhaust a true dual exhaust. Runs so rich now I am only getting about 26 mpg.. can barely get 140 miles before I have to hit reserve..
Any help is appreciated..
( ...and yes....I did a search and nada came up...)
Is it held to the intake manifold with a 2 bolt flange or slip fit into a rubber sleeve?
Good quality pics are best, minus the air cleaner and backing plate to help identify.
Your bike should have a Keihin CV carb on it and it uses the rubber slip fit sleeve to seal up on the manifold, no bolts.
jim
jim
houdinitattoo
Exhaust System Topics
04-09-2008 01:36 AM
1979, 883, 94, bedfordshire, carb, carburetors, cvk, eagle, harley, hd, identify, identifying, keihin, parts, screaming
