Vacuum (VOES) fitting keihin CV
Hello,This looks an awful lot like the brass replacement that is available from HD to replace the plastic fuel inlet.I don't have my parts manual right now ,but most dealers should have this because of the eventual failure of the original plastic inlet.I am not positive if they are the same size though.Cheers,Ed
It should be a press fit. Find a piece of small copper/brass tubing at a hardware or hobby shop that fits into your petcock/VOES tubing. Then if you have to carefully drill out the body and replace it with the tubing that has a very,very small amount of J-B weld on the outside only. By the way, how in heavens name did you break that thing?????
