Crane 8-3101 Hi 4E Ignition Module Wiring
Hey there, I thought I might try this forum
Can someone do me a favor and let me know the wiring colors to pin #'s for the Crane H-4E ignition module (8-3101, the one that has the 8-pin deutsch connector) - a picture would be great!!
I scored a used 7-pin module on ebay (8-3100), which I will convert to fit my 1998 Fat Boy but I need to know which color wires go to which pins on the Deutsch connector. I can get an adapter, but they work out too expensive by the time I get it to NZ
Cheers!
Cheers!
hrm. wiring harness looks identical to the Dyna2000p (minus I think dyna uses blue for the rear-cyl coil *if running as a single fire ignition*)
if ya need, I have a 98 RKC (was your EFI? or always carb?)...that I made my own ignition interconnect harness for (got the pinouts listed with descriptions on what each wire does)
let me know if it'll help
Hey Stu,
Not if you are looking for the basic wiring diagram, here is a link
( http://www.nightrider.com/biketech/d...stall_hi4e.pdf ) hope it helps.
Cheers
Cheers
My understanding is that the 7-pin & 8-pin Hi-4e's are identical except for the plugs. So I'm going to cut the plug off my 7-pin module and connect an 8-pin deutsch connector - should be easy!!
But I need to know what color wire goes to what number pin. Basically all I need is a picture of an existing module showing the wires going to the deutsch connector.
This might work
Cheers STU
Hi Jasper,
Would your Dyna Ignition diagram be the same for the Crane Cams 4I-4E module?
I am looking for the function of each wire that goes into the 7 pin plug as I want to wire it directly without any plugs.
The 7 wires are:
-Red
-Purple
-Blue
-Black
-Green with white
-Red with white
-Black with white
The 7 wires are:
-Red
-Purple
-Blue
-Black
-Green with white
-Red with white
-Black with white
Jimpool
02-16-2013 05:52 PM
stuboy-2001
12-29-2012 03:03 PM
