Milling heads to raise compression.
Hi all ., have read the previous discussions regarding milling to bump up comp. ratios and there is a lot of info. but im still left with a simple question regarding my own particular situation.
Im doing a top end rebuild on a 1990 FLT EVO motor including .,
replacing the lifters with Johnson V2303 , Andrews EV27 cam , CV carb. stage upgrade and intend to use the original pushrods .
My question is ... is it ok. to simply mill the heads to get the oem comp. ratio from 8.5 / 1 to a more effective 9.5 / 1 comp. ratio ?
I agree with grbrown and miacycles. I don't think you'll be able to go from 8.5 to 9.5 by milling the heads, but having the shop cc them would be a good start. IMO have them shaved to be equal cc's but as close to stock as you can, and throw a set of hc pistons.
While I prefer adjustables, the ev27 cam is usable with stock pushrods. If you shave .010 off the heads, the pushrod will be .010 deeper in the lifter. The hydraulic lifters have more than enough room to absorb something like .010 or .015 difference. But its still something to keep in mind when you start decking the heads...
