86' EVO starting problems, possibly solenoid?
heres what I got 86' FXWG (think shovelhead starting system)....just installed a new spyke starter and pull start solenoid, fully charged HD battery. I pull the solenoid button, the starter just spins and nothing but the starter drive (or bendix) in the primary moves. If I use a screwdriver I press against the plunger then the jackshaft moves outward towards the starter ring gear but the starter doesn't actuate? Does this sound like a bad solenoid? Or the spring that goes inside of the plunger be too weak to pull the starter drive/jackshaft? I've been through the HD manual, I've talked to a 40 yr certified HD tech that can't figure it out either (over the phone, he lives too far away.) I'm thinking its a mechanical issue...but I could be wrong. Any help would be greatly appreciated. Ben
Received 3,220 Likes
LtlNicky
02-07-2014 12:44 AM
