Am I getting the "click of death?"
Went out to the bike, started it and it cranked for awhile and than I heard a clickclickclickclick like it had a bad starter, than it cranked normally again. The battery cables are new, I thought I saw some blue smoke on the primary side (electrical smoke) but cant be certain. I was thinking of pulling off the solenoid as the dealer said they replaced the starter (it has been about a year and a half). I was going to disassemble the solenoid and see what I can't see. Everything is charging normally since it is intermittent I am trying to figure out what would click.....the starter or the solenoid?
Thank you
Jesse
Thank you
Jesse
The solenoid is the most likely thing to"click", but anything that causes low voltage will cause it to do so. I would check the starter relay first. If you indeed had smoke, it is most likely the starter. Hitachi starters are notorious for the through bolts shorting out, and causing smoke.
Went out to the bike, started it and it cranked for awhile and than I heard a click click click click like it had a bad starter, than it cranked normally again. The battery cables are new, I thought I saw some blue smoke on the primary side (electrical smoke) but cant be certain. I was thinking of pulling off the solenoid as the dealer said they replaced the starter (it has been about a year and a half). I was going to disassemble the solenoid and see what I can't see. Everything is charging normally since it is intermittent I am trying to figure out what would click.....the starter or the solenoid?
Thank you
Jesse
Thank you
Jesse
If it click click click click you know all is well to the solenoid which is just a big electric magnet. Until it has good 12.7 volts and enough amps to pull it to contact the big contact that turns the starter on, do not condemn the starter. It actually take more volts (not amps) to pull in then the starter needs to run. Now if it just made one click and the starter did not run, then it could be the starter or the actually big contact that starts the starter that the solenoid bumps into on the way to push in the starter sprag clutch gear. You probably have a weak battery or a bad connection at the battery or the big wire on the solenoid. This is not exactly your system but close and same principal
Received 70,392 Likes
Received 4,317 Likes
If you are getting a series of clicks you don't have "the dreaded click".
A series of clicks is caused by one of two things.
1 A weak battery
2 A bad solenoid
Do you have a battery tender on your bike?
If so leave it hooked up when you start your bike and if you still get the series of clicks then you have a bad solenoid if you don't you have a weak battery.
1 A weak battery
2 A bad solenoid
