New cam/rods/lifters and bearing and ticking!
So I just put a V-thunder 3020 cam (reused stock gear), new torrington bearing, Johnson hylift lifters and v thunder adjustable pushrods. Got it all back together runs great, but now I have what sounds like a lifter tick, especially noticeable when warmed up. Adjusted pushrods 3 time to what they call for (zero lash, plus 3 turns), and it still ticks.
Should I try adding and 1/8 - 1/4 turn on pushrods?
Thanks!
Thanks!
I have not cut valve guides. I have installed a couple different cams in evo's, and I havent ran into that yet.
It only is noticeable when bike is fully warmed up. And I did check exhaust gasket to rule that out, and it does not seem to be coming from there. Sounds exactly like a lifter tick. not terrible, just there..
what color code was your original cam gear?
[QUOTE=fastmofo01;12752228]I have not cut valve guides. I have installed a couple different cams in evo's, and I havent ran into that yet.
there..[/QUOTE
I had green code which I later found out have the guide height issue.
there..[/QUOTE
