Fork tubes. Condition thereof for good oil seal replacement?
My left fork is leaking oil. I replaced the oil seal last year for this reason and it seemed fixed ( a few hundred miles worth ) until recently. I have removed and disassembled the left leg and will replace seal and bushings.
My question is, how "pristine" need the fork tube be to not cause the fork oil to leak past the seal? Currently the tube has a couple of small scuffs on it and when held under the light, some fine scratches are visible. I am wondering if the fork tube may be the root of this issue. Or it could just be my reassembly I suppose. The right leg has similar scratches too, but does not leak.
This is a 39mm front end, from a 99 dyna sport (I was told), on my 83 FXR.
Thanks to those that may reply.
