How to: Replace broken shifter pawl spring.
#41
Here's their website....
http://www.jirehcycles.com/
877-681-0448
You cannot PM yet. You do not have enough posts....
877-681-0448
#43
shift pawl spring replacement
So your shift pawl spring broke. Don't panic.Don't run out and buy a couple hundred dollars worth of H-D "special tools".Don't pay $1,000 to get it fixed.No it doesn't take all weekend to do.Yes,it's quite a bit of work, but the entire job takes about 6 hours and will cost you $30-$50 ( It cost me $30 because I re-used most of my gaskets,except the trap door gasket).After removing the: Inner and outer primary,oil tank,pipes,top tranny cover etc. I then removed the trap door on my wifes '92 Springer Softail,carefully. I used small wooden wedges and a rubber mallet with soft taps around the door.Remove the shift drum and shift forks (don't be scared they can only go back in one way).Slide the compensating shaft out (the front gear shaft) and remove the shift pawl and replace the spring. Unless the pawl assembly is damaged you can just replace the $3.47 spring available through your local dealer.Put the bike back together and ride it.Be carefull when removing the front shaft not to disturb the outer gear on the tranny mainshaft too much as it rides on a needle bearing.Replace your fluids and any gaskets that are un-reusable along the way.If your bearings,seals and other items in the tranny are not disturbed (because your not pulling the front final drive sprocket or belt) you don't need to replace them. Took me 6 hours with a decent amount of tools (and a few beer breaks).As I said total cost with fluids was $30 and change at my H-D dealer. And I didn't use any "special" Harley tools. Just wanted to get this out there as too many people will tell you all the stuff you can't do.I've been fixing these very basic machines (Harleys) for almost 40 years and I've never let people talk me out of fixing anything or into anything expensive.
The following 2 users liked this post by knifeman1:
BisbeeDyna (08-04-2016),
tar_snake (11-15-2016)
#44
EvoBoy (09-27-2016)
#46
#47
#48
#49
I am doing a similar job on my 1991 Fatboy and have pretty much removed what I need to as per the manual. My problem right now is I can’t get the inner primary off. All bolts etc are off and there is nothing that I can see holding it on, except the roller bearing on the main shaft. I have searched everywhere and no one seems to have had that problem, any advice? It looks like the rollers within the roller bearing are sitting behind the lip on the spacer on the main shaft. I obviously don’t want to force anything, but for the life of me, I can’t figure it out.
#50
Received 4,324 Likes
2 Do you have a picture so that we can see what you're seeing?
