S&S Cams & Lifters
S&S Cams & Lifters
For Sale 2 S&S Cams for an Evo - a 502 grind and a 520 grind - 1 set of 4 S&S 33-5342 lifters and 1 cam gear - everything is used and in good shape.
The 502 is a bolt in cam .500 lift - fine for a stock motor or small stroker - stock compression to - 9.5/1.
The 520 is a bigger lift- requires spring spacing - it is fine for a bigger motor or more compression to 10 / 1 but it is not required
You can try both cams and see which works best for you. I usually end up trying multiple cams in my bike & buying used cams makes it affordable - I have had 5-6 cams in my 03 .
The cam gear can be installed advanced or retarded to adjust the cam timing & fine tune the cams for your application
These cams & lifters have very little use - they were changed out for bigger cams years ago and have been on the shelf. look at the pics
$125.00 Shipped to a USA Address in the Lower 48 States
Information on the cams
from S&S Web page
Part Cam
Name Application
33-5075 S&S Stock 80” to 89” lift In .500” Ex.500” .Duration In 248 Ex 254 Hydraulic Lifter - Bolt-In
502 CR 8.5:1 to 9.5:1
33-5073 S&S Engines to 96” Lift In .520 Ex .520 Duration In 220° Ex 232° . Hydraulic Lifter - requires spring spacing
520 CR 8.5:1 to 10:1
from S&S Web page
Part Cam
Name Application
