solenoid clicks, will not start
2000 FXDL. solenoid clicks, will not start... new starter and battery
Sounds like you have the dreaded click.
But first get your DMM and check voltage at the green wire going into your starter. It might be that you need a new starter relay. |
If it does turn out to be the solenoid, in order to buy a little time, you can take the solenoid apart and clean off the copper washer inside of it with a stiff wire brush.
Just make sure you buy a new solenoid asap. :) |
Originally Posted by prplglide
(Post 16818779)
Originally Posted by texashillcountry
(Post 16818858)
The new starter the OP got should have come with a new solenoid.
Originally Posted by FXDL32966
(Post 16818729)
"jump" the solenoid with a piece of wire...big wire to little wire...if it works the problem is the control wiring on the bike...if it doesn't it is still a starter/battery problem. |
Originally Posted by Tom84FXST
(Post 16819191)
(Post 16818858)
look at the grounds , both terminal ends and where the starter attaches to the bike
My current project had this issue, so the OP put one of them push button things on the solenoid to bypass the electrics of starting. Turns out the little connector on top of the solenoid, the one where the green wire goes, was spun around too many times and broke the internal wire. So last night I soldered an extension on the wire and re-soldered it to the connector inside the solenoid. Works great now.
© 2024 MH Sub I, LLC dba Internet Brands
