TourGlide wiring fun
Old Nov 27, 2018 | 09:44 AM
SteddyTeddy's Avatar
SteddyTeddy
I know everyone says its common but I have a similar issue on my 94FLH. Voltage gauge drops to 10v every time I hit the brakes. The head light also dims. I noticed over the weekend that when I had my wideband gauge plugged into my cig lighter socket, my turn signals would not come on and blink properly.
Old Nov 28, 2018 | 04:59 AM
grbrown's Avatar
grbrown
Talking
I recommend starting with Tom's suggestion above. Most electrical 'problems' of this type are not electrical but mechanical. The simple act of applying a brake and getting a voltage reduction is most likely down to dirty/oily/loose/corroded contacts. There aren't many such candidates in brake light wiring! Clean, tighten and apply a little dialectric grease. Check every ground, by disconnecting it, cleaning etc. Pull apart multi-pin connectors, carefully, and ditto. This is little different to spring cleaning around the house and dusting the tops of those tall items of furniture! There is bound to be a eureka moment along the way.....
Old Nov 30, 2018 | 10:15 PM
Tee&Vee's Avatar
Tee&Vee
so. . you can teach an old dog new tricks! Graham didn't mention earthing. Nice, he's learning proper English!
Old Dec 1, 2018 | 07:46 AM
Kingglide549's Avatar
Kingglide549
Yes, - and when everyone discovers power actually comes out of the negative terminal
Page one can be turned.
The Brits are the only one that got the ground plane correct. in cars. (Neg ground)
Old Dec 1, 2018 | 08:20 AM
86glider's Avatar
86glider
I've had similar problems on my 86.I found weak connections at the mylox connectors. I ended up making solid connections.Keep in mind the anti-dive solenoid valve draws a bit when hitting the brakes.
Lingleha
Jul 8, 2012 06:07 PM
richard 58
Oct 17, 2010 09:06 AM
Thunder Road SF
Jul 26, 2010 01:18 PM
windsoreight
EVO
18
Aug 16, 2009 08:42 AM
Jinxie
EVO
Sep 12, 2007 11:19 AM
