View Poll Results: 93 EVO 15000 miles best basic mods
what is best lower priced cam
33.33%
what are best carbs for general use or stay stock
66.67%
Voters: 3. You may not vote on this poll
93 Heritage EVO fixes
Old May 3, 2021 | 10:58 PM
spudnut's Avatar
spudnut
Stage III
Arrow 93 Heritage EVO fixes
new member Hello from Alberta.. just curious about advice on my new 'old' bike 93 evo 22000k about 14000 miles.dont want big inch thx. No big $$$ ..cam,,pistons ,heads,,new gaskets,carb , etc. suggestions welcome keep it basic..slight seepage
Old May 4, 2021 | 06:48 AM
mike131's Avatar
mike131
Welcome to the forum! Off the top of my head, inner cam bearing they fail and trash the engine also the lifters will do the same thing, do a compression and leak down test, but you are really low mileage, so I wouldn't worry about anything yet, I use Cometic head gaskets and base gaskets for the EVO and I find EVOs like conventional oil and like to seep synthetic oil
Old May 4, 2021 | 06:54 AM
mike131's Avatar
mike131
I'm not going to get into carbs and cams, you will get all different opinions on that here
Old May 4, 2021 | 07:01 AM
mike131's Avatar
mike131
S&S supper E, Keihin CV 40, Mikuni HSR42 all work well, cams this page, http://www.nightrider.com/biketech/hdstage2.htm
Old May 4, 2021 | 07:07 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
The lifters that came in Evo`s through the late 90`s had problems with failure of the rollers.
New OEM lifters are good, also S&S, Johnson Hy Lift. Avoid no name lifters.
The bearing you need is Torrington or Koyo B-138.
Also get rid of the original transmission sprocket and spacer and replace with the upgraded pars (`95 and later), the original front sprocket retaining nut was notorious for coming loose.
Old May 4, 2021 | 07:25 AM
0maha's Avatar
0maha
Nice score! We, of course, require pix.
My $0.02: Modifying an engine needs to be done with a purpose in mind. It runs fine now, right? What makes you want to change it? What do you want the bike to do after the work that it doesn't do now?
Answer that question, and every other question answers itself. Or at least those answers are way narrowed down.
Old May 4, 2021 | 07:30 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Toss the oem brake pedal into the scrap can, and install a pedal from Soft Brake.
OEM brake pedal
Soft Brake Pedal
Old May 4, 2021 | 05:03 PM
spudnut's Avatar
spudnut
Stage III
thx usefull
Old May 4, 2021 | 05:19 PM
spudnut's Avatar
spudnut
Stage III
Default omaha
thx not doing it till winter .see seepage around top end. on my past 08 SG, 2 -RK's highway speed avg.130 k [in american 75-80 mph ?] twin cams.. my 94 rk was cammed ,ported heads different pistons etc..it was great ...traded in for sg ..kick myself for that
Mauidaid
Sep 11, 2014 02:40 AM
Spankinhenken
EVO
35
Jul 8, 2013 09:35 AM
jclark311
Nov 4, 2008 09:35 PM
Frisian HD
EVO
23
Aug 28, 2008 10:45 PM
medic2980
EVO
Aug 20, 2008 07:23 AM
