Harley Davidson Forums
Harley Davidson Forums (https://www.hdforums.com/forum/)
-   EVO (https://www.hdforums.com/forum/evo-84/)
-   -   speedometer cable doesn't match. (https://www.hdforums.com/forum/evo/1448536-speedometer-cable-doesnt-match.html)
97HS Jan 11, 2024 12:59 AM
Hello gentlemen.
I' m running 1991 softail.
Recently, I changed my front wheel with the older used wheel of harley . maybe that of shovelhead??
Now, the problem is, my speedometer system doesn't match this wheel.
I don't have any knowledge about this wheel.
Anyone would give me advice I must follow to install speedo cable system?
Here are pictures of the wheel .
Thanks for any answer in advance.
https://cimg4.ibsrv.net/gimg/www.hdf...8c4bb3a948.jpg
https://cimg5.ibsrv.net/gimg/www.hdf...ec54ee5595.jpg
eighteight Jan 11, 2024 03:38 AM
That" Star Hub" wheel came off an older bike with the speedo driven from the transmission
Therefore, there is no provision for a speedo drive
Architect Jan 11, 2024 06:41 AM
And there is your answer.
97HS Jan 11, 2024 08:13 PM
Thanks.
I think there is no other way but change the wheel to "modern" one.
I can install 16" evo front wheels before 1996 to my ride?
I was told the speedos chagned electric after 1997.
If I' wrong, correct me.
thanks.
97HS Jan 11, 2024 08:28 PM
Thanks.
I 've changed my FX front end with that of old classic springer front assembly.
All is good ,,,,until this issue pops up.
I'm rolling my head ,
Through which year can i use 16" wheel without mistake..
Do you have any advice?
https://cimg8.ibsrv.net/gimg/www.hdf...a19dbacd9f.png
eighteight Jan 12, 2024 05:51 AM
[QUOTE=97HS;
[/QUOTE]
Yes & no , there are variations due to models.
For instance , first year (` 94 ) Road Kings had electronic speedometers, other models did not switch till later
You need to spend some hours on Ronnies Parts Finder deciphering the various parts numbers
Or put a GPS on your handlebars and run what you have
97HS Jan 12, 2024 07:04 AM
Oh, confusing but thank you for answer.
How about evo FL softail model ? I''m leaning to FL softail models since mine is FXSTS model.
There are also variations among Evo FL softail models due to the years?
I ve found this wheel on Ebay I'm cautious though.
https://www.ebay.com/itm/126264160329
This will fit?
eighteight Jan 12, 2024 07:38 AM
Originally Posted by 97HS (Post 21523226)
I hesitate to say yes due to you being overseas
Member Multihdrdr is the wheel fitment guru here, I suggest asking him
Heritage had a cable drive through `95 , that wheel p/n is 43005-86
My worry is that exploded view of the wheel doesn`t show the speedo drive unit.
I admit I do not know
Racepres Jan 12, 2024 07:59 AM
That FLST wheel Should work on any Softail...In Fact...I have one on a 4 speed FLH
Spacers May need to be Made!!
Special Note...Springer Softail Front Wheels are laced Offset..Take Heed and Caution
FLHRinFL Jan 12, 2024 08:25 AM
Originally Posted by 97HS (Post 21523000)
Thanks.
thanks.
As mentioned, all Road Kings are electronic speedometer. 1995 was the last year for the mechanical speedometer on the Softail models.
© 2026 MH Sub I, LLC dba Internet Brands
