Engine Setup's Stock 80 Only
Just thought I would start a thread on engine setup's and see what everybody has and is working for them, Maybe it will help me an others get an Idea of where to start there tune. Here is what I have
1994 Evo Stock 80" K&N Air filter Stock headers W/ Rush 2.25 baffles Mikuni 42 160 Main, 22.5 Pilot Std 97 Needle W/clip 4th Notch Richer, #70 Pump Nozzle Going to change baffles to 1.75 but not for sure on the jetting!! |
You should probably limit it to '80" engines, that way the results would be more comparable. This would make the thread more pertinent.
That being said our favorite '80" engine would have the following: Forged 10.5 pistons, single fire ignition, Mikuni 42mm, reworked heads(your pocketbook is the limiting factor), a woods cam(the grind depends on weight and driving style), 31/30 tooth tranny sprocket, a good 2-1 exhaust(RB racing). That would give you a good running 80" engine. You could also do a Hemi-Head conversion, those engines really rock, the torque numbers usually run about 10-15 above a regular engine. Hope this helps and I am looking forward to the others combos. |
Good suggestion I would like to limit it to the stock 80"
This is going far!!!
Stoke bore, K&N, Power commander, SE fishtails with baffles vented slightly, Biff wiffle muffler bearings, Stainless steel anti honda aspencade catcher mounted on my 15 puck full race disc calipers and high speed timpkin vibrolater mounted under the rear seat area. :)
1985 FXEF Superglide
EV35 Cam Notched Pistons (for clearance) Titanium collars Adjustable Pushrods S&S E Crane HI4 HI4 is new (last year) but ran the rest of this set up for about 15 years now. |
96' Wide Glide 80" EVO
Andrews EV27 cam, V-Thunder pushrods Mikuni HSR42 165 main 22.5 pilot #50a/p nozzle Ness Big Sucker V&H Big Radius w/ B.C.T QQ series baffles. Dyna 2ki running single fire. |
'96 FLSTN 80" EVO--Longevity Build
Woods W6 cam .510 lift 9.7:1 Heads (by Hillside--thanks again Scott) Cometic .030 head gaskets James .045 base gaskets Kibblewhite valves and seals 1.62 intake/1.90 exhaust S&S Lifters Crane Timesaver PRs Andrews Valve Springs (not sure of spring weight) S&S E 280 intermediate / 176 Primary DTT ignition and SF coil 6.5 in/HG Voes switch Kromewerks HP+ on original crossover header Similar builds generally run approx +- 80hp / +-85 ft. lbs never been on a dyno-- don't need it--- seat of pants says GOOD FUN! (and blows off 88" twinkies easily) |
1998 FXSTC
Stock 80" Evolution V-Twin Engine Vance & Hines Big Radius Exhaust Pipes Andrews EV-27 Performance Cam Mikuni 42 Carburetor Crane Single Fire Ignition Arlen Ness Big Sucker Air Cleaner |
Specs below....
| All times are GMT -5. The time now is 09:00 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
