After thinking about it, they might be using the map sensor as a voes if it is a on/off type of switch instead of a 5 volt referance. No voes listed in parts list.
I picked up a CV carb, completly rebuilt it back to stock, put a 46 pilot jet and a 190 main a CV performance velocity needle and emulsion tube.
I also picked up a screaming eagle ignition module and coil kit brand new from a member here.
All of my parts are on the way from Zanotti's so next week hopefully I can get going on this Job.
Thanks for the input on the map sensor, I have a late model year manifold there has to be something on the M&M that plugs that hole the guy Iv'e been talking to used it to plug his???....lol.
Going with the pingle tank conversion kit but using a Goland petcock, I like them way better than Pingles, positive ball detent stops in all three positions, they are the bomb.
Hope you guys all have smooth transitions with this job, should be a lot of fum I'm looking forward to digging in.
I just got my 1996 Ultra carb so I can keep the cruise control. Picked up a manifold and am waiting on an aircleaner setup. I've got a Dyna 2000i coming and am down to the small parts to collect. I'll get rid of that poor fuel economy MM POS soon. (1996 on mine)
