99 fxr here
Old Nov 22, 2011 | 09:37 AM
99HarleyFXR's Avatar
99HarleyFXR
Default 99 fxr here
What company makes the stroked conversion or just a bigger inch conversion for the EVO engine on my bike?
How much does it cost?
Is there a better kit and brand than others?
Old Nov 22, 2011 | 10:04 AM
grbrown's Avatar
grbrown
Let's start again! Are you saying your bike has a conversion? If so what do you know about it? There are plenty of after-market engines available.
Old Nov 22, 2011 | 12:52 PM
Spanners39's Avatar
Spanners39
S&S would be the way to go if you ask me, they been around a long time.
Old Nov 22, 2011 | 06:14 PM
1skrewsloose's Avatar
1skrewsloose
What leads you to believe you have a stroked or modified motor? Seller give you a line of BS? Just askin. Maybe I misread your post. The only real way to know is to tear it apart and take measurements.
Old Nov 22, 2011 | 09:54 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
The way I read it you are looking to stroke your motor.
In my humble opinion if you want a bigger motor buy one that was built that way and it will last you a lot longer.
Old Nov 23, 2011 | 12:56 AM
Spanners39's Avatar
Spanners39
True but stroked Evo's totally rock!!
Old Nov 23, 2011 | 08:54 AM
texashillcountry
Dirt don't hurt
What is the difference between a stroked motor and a purpose built motor of equivalent size?
Old Nov 23, 2011 | 02:33 PM
grbrown's Avatar
grbrown
My 89" stroker is the original motor stripped and rebuilt with different flywheels, that give the longer stroke, plus a stack of other tuning mods, such as Sportster high comp pistons, ported heads, new cam.
A purpose built motor will most likely have a larger bore, not a longer stroke, to get the extra inches. There is no certainty it will be as highly tuned as a custom-built stroker.
Old Nov 23, 2011 | 02:39 PM
Spanners39's Avatar
Spanners39
Long stroke equals high torque and a very long-legged motor...downside is high piston speed and oil consumption.....but I would seriously consider one if and when my 98 needs a full rebuild.
Old Nov 23, 2011 | 05:02 PM
woodnbow's Avatar
woodnbow
Spanner, what would you expect in terms of oil consumption? I'm considering the Jims Stroker kit for my '93 FXRS. Would you expect the same oil consumption from a stroked motor like the Ultimas or S&S?
