Turn signal help needed
Old Jan 27, 2013 | 04:36 PM
falconbrother's Avatar
falconbrother
Default Turn signal help needed
I have a 1988 FLHTC. She's a fine machine. Everything works but, one thing. The turn signals wont stay on when the button(s) are released. Is this part of the relay? My service book says that the relay or module or whatever is mounted to the fork under the fairing and can be accessed behind the headlight. I can see the forks and don't see relay the first?
Is the self canceling function part of the relay it's self? It's a shade hard to drive, work levers and hold the turn signal button.
Old Jan 27, 2013 | 05:17 PM
grbrown's Avatar
grbrown
Wink
The stock flasher unit is a large black module, bigger than a packet of cigarettes, attached to the right-hand fork leg between the trees using zip ties. However your bike has been around long enough for a previous owner to have junked it. I replaced mine several years ago and it was darned expensive!
We had a recent thread on this same subject, where I believe a Badlands module was mentioned as an alternative. This thread is one that may help.
Old Jan 27, 2013 | 05:56 PM
bluharley's Avatar
bluharley
That's how my 1988 is. It's designed that way! Some day I'll get a Badlands module. Maybe your model had the self canceling system, mine doesn't, never did.
Old Jan 27, 2013 | 08:00 PM
Mountainkowboy's Avatar
Mountainkowboy
The module on mine was mounted to the fork leg...........it would blink for like 8 times and shut them off. I diconected the speedometer sense wire so I had to turn them off manually.
Old Jan 28, 2013 | 05:03 AM
grbrown's Avatar
grbrown
Thumbs up
I did the same! It's white/green and easily disconnected.
Old Jan 28, 2013 | 08:06 AM
falconbrother
Well, if it was designed that way I might just decide that I don't care and leave it the way it is. Or cut that green and white wire. That sounds pretty good.
Old Jan 28, 2013 | 08:32 AM
grbrown's Avatar
grbrown
Wink
The white/green wire has a plastic connector a few inches from the instrument cluster, which you just need to pull apart. Each end of the wire is insulated, so they are safe to leave lying where they land.
Old Jan 28, 2013 | 06:56 PM
machinehed's Avatar
machinehed
Check the connections at the modual before you do anything else.
Tycer
EVO
May 26, 2017 04:38 AM
0maha
EVO
17
Jul 22, 2014 06:50 AM
WVICEMAN
EVO
May 3, 2013 08:11 PM
larsfum
EVO
Jan 12, 2011 11:02 AM
strongwood
Dec 13, 2010 06:44 PM
