2-1 exhaust drone
2-1 exhaust drone
Ok fellas, Just wanted to hear your experience. I took off my 2-2 hooker exhaust and put my old python 2-1 exhaust back on. When cruising at a constant rpm I get an exhaust drone. It kind of gets annoying. Is this a common feature of the 2-1 exhaust setups?
Also, and I could be losing my mind, but it seems I get more engine vibration with the 2-1 then I do with the 2-2. Just not quite as "smooth" I guess. Hard to explain, like I said maybe I'm losing my mind. I like the power curve it produces but just wanted to know if this was just part of the exhaust.
I have not had it dyno tuned. Just using a canned map on the PCV.
So, drone, and vibration. Normal?
My bet is the canned map isn't doing you any favors, a good tuner with a dyno should be able to settle down that vibration. IMO, canned maps are for those who think close enough is good enough.
