Rhinehart true duels Exhaust gasket
I'm told the HD tapered gasket is the best choice for Rhinehart true-duels, however … the tapered HD gasket is the exact same size (1.9" dia) as the Rhinehart exhaust pipe flange
No matter how centered the pipe to gasket is or how hard I try, the studs will not protrude thru the flange nuts. In other words; there ain't no threads showing when the pipes are tightened! The Rhinehart head pipe is same as the one I installed.
The pipe flange & exhaust gasket outside diameters are both 1.9"
Were you able to remove all of the old gaskets first before trying to install the new ones? It sounds like the new gaskets are not seated all the way into the exhaust ports due to either the old gasket(s) being still in, or partly remaining, and/or the new gaskets were not seated all the way into the exhaust ports. Any of these conditions will not allow the exhaust pipes to fit deeply enough into the exhaust port for the bolts to reach past the exhaust studs.
See:
Hopefully that will help.
The diameter of the pipes themselves should not pose too much of a problem. If they do, you can always go with the flat gaskets that are shown in the video.
Ride Safe!
See:
Ride Safe!
