Sponsored by: Jekill and Hyde
Copper exhaust gasket vs Harley OEM??
Old 05-20-2017, 04:06 PM
rdunkin1986's Avatar
rdunkin1986
rdunkin1986 is offline
6th Gear
Default Copper exhaust gasket vs Harley OEM??
So I'm putting on new headers and I'm replacing the old exhaust gaskets. I've read good things about the copper exhaust gaskets but has anyone actually used them? Harley is telling me that they leak and that I need to use OEM cone style gasket. Any advice?
Old 05-20-2017, 08:23 PM
target64's Avatar
target64
target64 is offline
I have used the novello copper crush seals with v&h big shots, bassani, thunder header and have had no leak issues. and they don't block the exhaust ports on the heads when flange is tighten like the SE ones do.
Old 05-22-2017, 04:13 AM
bklynbob's Avatar
bklynbob
bklynbob is offline
I've used the Novello coppers on a few bikes.
Old 05-23-2017, 09:07 AM
TXWarthog's Avatar
TXWarthog
TXWarthog is offline
Every bike I've ever rebuilt has used copper crush seals (albeit, many were Japanese bikes). I've had no problem with the seals. They work well, but are a one-time use. If you pull the exhaust, you SHOULD replace them (I've reused them once or twice when in a pinch and had no problems).
Now a cone style gasket is a different beast. The cone shape is supposed to help with back pressure and preventing the popping and backfiring out of straight exhaust. Talking to some of the OLD riders, in the 70's and 80's, they didn't have the cone gaskets/inserts. To solve the back pressure problem, they would drill a hole completely through the exhaust (toward the bottom of the header) and install a nut & bolt. Does it work? I don't know know, but they swore by it.
jlasoftail
07-04-2021 12:03 PM
whataboutbob
06-27-2012 12:31 PM
jaybull
02-28-2012 03:30 PM
Rickr01
05-07-2011 08:20 PM
JakesDad1
03-25-2011 09:55 AM
Quick Reply: Copper exhaust gasket vs Harley OEM??
