Question about slip on's
Hi all I have a 1990 hd 883. It was a one owner bike with 10k all stock. I got a set of screaming eagle slip on mufflers with the baffles in them. I have been riding the bike for about 600 miles and the only thing done to the carb was a cleaning and it seems to run good. Recently I pulled the baffles out to make it a little louder even though it is loud as it is which I couldn't believe with just slip on's. Anyway I went for a ride the other night with the pipes open and it seemed like it was lugging pretty bad almost like a skip while driving down the road I figured I was in the wrong gear but it seem like no gear made it go away I can only contribute this to the muffler's so I put the baffles back in but I have not tested it again my question is with just the screaming Eagle 2 slip on mufflers with the baffles in should I reject the bike and if I decided to remove the baffles to make it even louder what would you all recommend I rejet the bike to. I really do not have any idea what size the Jets are that in their bike at the moment I am assuming it is factory because I have all the paperwork and service history ever done and nothing about jet kit. Thanks all
http://supertrapp.com/product_sectio...temID=100-7580
This should give you more sound and performance if the SE2 slipons you have are still using the stock core that they came with.
