Heat shield keepers rusted out
The right rear lower heat shield assembly on my 2011 Ultra just started rattling. It seems as though the keepers/tabs (for lack of a better word) that the worm drive clamp slides through have rusted out and the clamp isn't holding the heat shield. A new heat shield is over $140. Is there any method one can fix this? Keep in mind I do not have any welding equipment.
I was thinking if I could get some tabs, like in the attached picture, that I could use some JB Weld High Heat Epoxy to attach them.
Wow, that is a very generous offer! I've attached a picture of the particular heat shield I need. On the parts diagram, it's number 25. Let me know if you have this particular heat shield and I'll then contact you via private message. Thank you.
dfwhockey17 (09-08-2017)
rhino49er
07-26-2007 08:30 PM
