What Vance and hines are these?
thanks mate I had a look on Google and they seem to be short shots. I'll have to email and find out about shipping
So after working out I have the worst performing 2-2 pipes what exhaust do u guys recommend? The current build is a 103ci, 10.8 comp, s&s 625 cams, ported heads, hpi 58mm tb. I'm hoping for around 120hp with a good system I love the rb racing pipes
I stand corrected the pipes are indeed short shots (apologies). The cams you are running having a quick glance are a cam set designed for 95” or larger engines with compression ratios between 10.0 and 10.75:1.
If you want maximum HP 635HO cams may have been better especially recommended for ported cylinder heads like yours. S & S also naturally recommend their own exhausts to compliment their performance enhancing modifications. Worth a look perhaps?
