Broken pipe. Can it be welded successfully?
I have a Hooker 2 into 1 exhaust on a 2002 Ultra, the pipe from the front cylinder has broken completely around about six inches before the merge. Can it be welded or am I going to have to bite the bullet and drop a grand on a new exhaust system? I haven't had much luck welding broken snowmobile and dirt bike exhaust, they seem to just crack again on one side or the other of the repair weld but those pipes were much thinner material.
I would appreciate any advice given.
teeroy_ (09-19-2017)
thanks. unfortunately I am the latter type of welder you describe. I can weld decent enough to fill or repair some non critical stuff on our heavy equipment trailers but I lack finesse (ie: skill) for the precision work needed for lighter material.
Well, it appears the damage is terminal. once I got the heatshield off the rear pipe I found the header was badly cracked and split. took it down to the fellas at the welding shop and it was frowns all around. they said they could try but it would be impossible to guarantee anything.
the front pipe where it is broken is pretty tight even to tig weld it properly because of a welded strap that ties the two pipes together. to cut everything apart and re-weld it all together might be throwing money away in the end. so new exhaust it is. RIP Hooker 2 into 1...
teeroy_ (09-20-2017)
talked to the builder and he thinks that they are just old and brittle, mine is the third bike these pipes have been mounted on. he suggested replacing them with the Vance & Hines Pro Pipe 2 into 1. says they will flow about the same and I shouldn't have to take it back to the dyno for a re-tune.
I've got a set of Rinehart true duals I'll slap on to finish out the season.
teeroy_ (09-21-2017)
excessive engine movement was my first thought too. stabilizer and front mount all good, chassis and engine were done in the spring of 2014. hoping it was just old and brittle pipes, got my old set of Rineharts on today. heading out in the morning for a three day tour, catch a couple preseason hockey games in Edmonton tomorrow and saturday, and toodle back up north on sunday.
