Which gasket oem or se?
Just about to install my exhaust but I'm getting mixed reviews on which gasket to go for. The exhaust is squared not tapered but some posts on this forum say to still use the tapered oem gasket instead of the screaming eagle because the se gaskets are prone to leaking. But wouldn't a square exhaust on a tapered gasket leak anyways?
Recently installed the Cobra Power Port header and it seemed to be a bit more squared. I went with the SE gaskets and no leaks yet. First time removing stock gasket, installing new and it was a little unnerving as didnt want any material to break off into head, all worked out fine. Really had to tug on the oem cone gasket to get it to let go.
WestTexasRanger
02-21-2013 04:13 PM
