Is decel popping hard on engine?
newhdrider21 (04-13-2018)
Pops are symptoms of a less than ideal tune.
Small clusters of light pops on light to moderate decel are often symptoms of running lean. How lean and in how many areas of your tune is hard to say without sampling some data. It can often be easy to fix but certain exhausts are more prone than others. I wouldnt be happy with a bike running lean. Air cooled engines run plenty hot even with a healthy fuel supply. Harmful to an engine?
Singular large pops after heavy throttle to no throttle suggest a rich tune, at least temporarily which is often limited to only certain parts of the tune and the acceleration enrichment table
The TTS user manual explains these things well and the tuning corrections that usually fix.
You don't need a TTS to read this. All flash tuning modules change the same tables of the Delphi ecu. TTS just went to the trouble of writing a really good manual.
Capt Steve
10-06-2017 03:00 PM
WideGlide29er
08-25-2013 08:13 PM
