Any recommendations on kits to change my 03 RK from the stock exhaust to a Dual?
I see some inexpensive kits out there that use the same shields.
Thinking Reinhart pipes and most likely go with Black. Chrome is not easy in FL.
I went with V&H true duals and used the Screaming Eagle slip ons that were on the bike when I bought it. They are still going strong. Easy peasy. Good luck with your choice.
One of the cheap kits is Fullsac, which I used for a while some years ago. It was OK and did what it was intended to do, including using stock heat-shields, but I didn't take to it. I now have a 2-into-1 one, which is something else!
Ok .
Grbrown I’m thinking 2 into 1 would not be that great on my 03 RK. Not even sure if i can find a Keep in touch. To convrt it.
I have an S&S 107" engine and ran my TDs for a while, even had the bike dyno tuned with them. I swapped to a Supermegs 2-into-1 and don't look back! The headline numbers for both systems were very close, however the 2-into-1 runs much smoother and gives up to 15% more torque in the low/mid rev range. Works a treat!
