I am nor mechanic but "Really"
So, I posted some time back asking about fullsac and true duals and I got all the standard, low end torque killer, etc. I like the sound. Anyway, i bought a set of Cobra True Dual head pipes and finally got around to taking my old exhaust off. Well, the dealership put the SE110 in this bike and the motor has 4000 miles on it now. Anyway, front head pipe bolts were not even finger tight, I put the socket on and when I went to move it to see if it was on all the way, the nut turned, both of them. The exhaust gasket looks like only half of it is there also. So, move to the rear pipe and the top not is loose and the bottom one was barely tight, oh and there was no gasket.
So, the exhaust leak I thought was my Y pipe cracked, welp, nope, the Y pipe looks like new. Damn man, the dealer did this work.
Anyway, I guess I know why they never could get the tune right either. So, I bought Vance and Hines gaskets when I ordered the pipes, should I use the OEM tapered style instead of those? Also, can you or should you use a little blue loctite on the exhaust bolts?, I know I need sensor type never seize for the O2.
Thanks, I think I am done ranting now, I guess I just expected better from a dealer install.
Campy Roadie (08-20-2018)
I didn't take it to the dealer for the work, they put the motor in the bike about 8 months before I bought it. They same dealer claimed to have dyno'd the bike twice but it didn't run right until I took it to another mechanic, I am still trying to learn the TTS so I had a mechanic tune it.
