Tune after swapping out stock exhaust?
I searched the forums for a thread similar to this (there must be one) but could not find it. I own a 2008 FXDL and it has the stock pipes. I intend on swapping them out for a set of Screamin' Eagle pipes and wanted to know if I need to retune the bike after the swap. If it was carburated, I'd think so but considering it's ESPFI, I question whether or not it would need to be retuned.
Thanks in advance for any feedback.
any assistance is appreciated.
J.T.
J.T.
My vote would be to get a Tuner, read here for more opinions as this is a frequent question https://www.hdforums.com/forum/touri...necessary.html
From my experience with EFI-normally a retune is only needed if you change the system to progressive stages or change the fuel mixture in any way. But not so much for a pipe change. It won't hurt to do it but it's not really needed if you're just changing pipes. The EFI should adjust to the slight change in exhaust flow. For Carbed bikes you most likely will need a different needle in the carb to change the flow.
