Wrapping baffles on V&H High-Output exhust
I know this subject is probably covered here somewhere and I'm not looking for it with the correct search. I think my question probably applies to other systems as well.
I recently traded up to a 2015 FLHTKL and it came with V&H exhaust system, headers and all. The High-Output slip-ons have no packing around the baffle and the bike seems to do okay with the tune, (it rarely has decel popping) but it's a little loud for me. I like loud, but after a good while on the bike it's mind-numbing. V&H sells a part called a baffle sock; part A260FG shown here: https://www.revzilla.com/assets/0002/0011/D239IN.pdf
They want 44 bucks each (and I'm sure shipping would have to be added on to that). Would there be anything wrong with using a generic wrap like this: https://www.revzilla.com/motorcycle/...le-packing-kit instead of the "baffle sock"?
I'm not crazy about the tone of these as-is, I was hoping some packing may take a little high-end click off the note and give it a little more bottom end. Would it change the tune enough to even matter if I wrap them? Thanks for the advice fellas.
Uncle Larry (06-04-2023)
I had some Rush slip-ons with fiberglass material around the baffles. I replaced it a couple of times. Then I wrapped them in stainless steel wool with fiberglass around the ss and got the sound and longevity I was looking for. Make sure the stainless is rated for mufflers.
Nothing wrong with generic packing. Some, as mentioned above use more durable materials. Some have even wrapped with fire place rope. It's a high heat rope like packing for fireplaces and such for dealing purposes. Likely you can get at Lowe's or similar. The results are generally a bit louder than loose packing, but should last indefinitely. Results will vary as well with Size of rope and how tightly it's wrapped.
Ceramic fiber is a little more durable than fiberglass and withstands the heat.
Something like this should do both mufflers
https://www.ebay.com/itm/Ceramic-Fib...EAAOSwjjpbD4vN
Received 47,784 Likes
Repacking the wrap on the baffles is a simple job ... Generic packing works fine ... Most dirt bike shops have it on the shelf ... Wrap the baffles then use masking tape to keep the wrapping in place when re-installing the baffles ... Using wire ( safety wire etc ) can cause discoloring ) hot spots ) on the chrome ... Seen it happen ... Good Luck
