Sponsored by: Jekill and Hyde
Nightstick slip ons / SuperTrapp plates
Old 01-29-2019, 11:06 PM
Jchaiyo's Avatar
Jchaiyo
Jchaiyo is offline
Default Nightstick slip ons / SuperTrapp plates
Hi y'all. 2015 ultra classic with nightstick slip ons. They are the SuperTrapp style with discs and a solid end cap. Any suggestions on removing the plates when the screws are all stripped? Also the screws on the bottom of the muffler are stripped too.
Old 02-06-2019, 03:17 PM
harkon's Avatar
harkon
harkon is offline
Aren't you lucky?
That's a tough one. You could try to dremel a notch in the screw head and see if you can get a screwdriver to get a good bite. Likely if they are stripped though, they are jammed in there pretty good. Probably the best bet is to weld a bold onto the screw heads. OR, you could try to grind off the heads to remove the discs and then just use some vice-grips to turn the leftover out. You will risk damaging the top disk either way. For the screws on the bottom of the muffler, you will risk damaging the chrome. Personally I would notch, and failing that weld a small bolt to what's left. Grinding the head off would be my last resort.
Old 02-07-2019, 06:35 PM
smitty901's Avatar
smitty901
smitty901 is offline
Received 9,561 Likes on 5,153 Posts
I ground off the heads removed the disk and used vise grips on them Then just replaced them. Used the good copper never stuff on the . Some times when you add more disks you need lone bolts anyway the come in the kit with disk. Still have some dist around here if anyone needs then Free.
Old 02-19-2019, 01:19 AM
Jchaiyo's Avatar
Jchaiyo
Jchaiyo is offline
You wouldn't have the part numbers for the 2 screws on the bottom of the exhaust would you?
Old 02-19-2019, 08:51 AM
smitty901's Avatar
smitty901
No I don't you can get them at hardware store . in SS or soft metal
stevensctt
03-25-2019 12:22 PM
BamaLion
05-21-2015 10:26 AM
GringoLoco
06-24-2007 02:18 PM
Badbagger
03-18-2007 01:30 PM
jaws134
05-14-2006 10:33 PM
Quick Reply: Nightstick slip ons / SuperTrapp plates
