Notices
Should I add an a crossover pipe?
Old 02-10-2019, 02:16 AM
Jesse Verne
Jesse Verne is offline
New Member
Default Should I add an a crossover pipe?
So I had drag pipes and I have quite a bit of engine work upgrades done to the bike I cut off the pipes and added the Rinehart slip-ons my question is should I add a crossover pipe if so where should I locate it I have Wiseco pistons 10 to 1 compression and 10 / stage 2 thunderstorm heads Andrews N8 cam Primo dynatek 2000i module twin Tec single fire coil Riviera Primo clutch
Old 02-10-2019, 07:43 AM
bustert
bustert is offline
that is a good?
will it help, probably.
if it were a car/truck, i could give some advise but on a mc, do not know if it would apply.
on the above, we would apply paint to the exh pipes and run the vehicle down the road and this would burn the paint in a certain area and this is where we would place the balance pipe.
Old 02-10-2019, 07:57 AM
Jesse Verne
New Member
Originally Posted by bustert View Post
that is a good?
I've heard of that on cars or truck thanks anyhow
Iceman24's Avatar
Iceman24
Iceman24 is offline
Big Kahuna HDF Member
Would be nice to know WTF kind of bike you're working on...throw us a bone here...
The Following User Says Thank You to Iceman24 For This Useful Post:
smitty901 (02-12-2019)
Old 02-10-2019, 07:58 AM
Jesse Verne
New Member
It's a 1200 sportster 1999 sorry
Old 02-12-2019, 09:05 AM
bustert
bustert is offline
two options here, follow the stock with cross-over by the jugs or hidden down by the lower rail, at least you know hd did r&r on the placement. OR, install a 2>1 exh, i run the danmoto highwayman.
Old 02-12-2019, 09:21 AM
grbrown's Avatar
grbrown
grbrown is online now
BSA introduced the cross-over pipe way back and every twin still uses something similar, to boost low/mid range torque, to this day. So they are a worthwhile feature, however I also agree with bustert - simply use a 'proper' 2-into-1 for best results. My choice is a SuperTrapp - they make them for big twins and Sporties.
Featured Sponsors
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
