Baffle questions.
Baffle questions.
So I bought a 2016 FXDLS that is bone stock. However the original owner has cut the baffles out. I've done a little research and am now worried about frying my engine from running too lean and too hot. I put in a 300 mile ride on it so far but that's about it.
Is it going to harm my engine that bad? What are your thoughts? Is there a cheap option to get by until I can afford the pipes and tuner that I want? Maybe buy a tuner first then re tune when I get an exhaust? Thanks in advance!
stock muffler?
are they blind ended? did he leave the perf tube?
if so, get a welsh plug, some say freeze plug and install it to blind the back of the perf tube. make sure you measure and go slow, if it goes out the back, you will have to pull the pipes and hopefully be able to remove it.
if that is not an option, just buy some baffles and install, put fastener on the bottom or rear so it cannot be seen.
that sounds like a decent idea. Especially if I dont have to buy a tuner right now. Trying to save up so I can pay the sales tax on this thing and work has been slow the last 2 weeks! Thanks for the info!
TOTALLY AGREE. You don't want to run the risk of damaging the motor (very expensive) or having sub-par performance; you will benefit from a high flow air cleaner as part of a complete Stage 1 upgrade. The upgrade can be done for around $800 if you do it yourself and shop for the components.
