Exhaust fiber shield wraps...removable?
Hey guys, while I send my shield to get ceramic coated, I was going to wrap my exhaust with wraps, just wondering if I will be able to remove them and use the shield once they are finished. Does anybody know for a fact? I'm assuming the heat and moisture will solidify them into the pipes, so I will probably have to scrape them off? Thank you for your help!
I have used header wraps in cars and on motorcycles before. I have never had an issue removing them. However, once they are exposed to heat they will loose the flexibility you have when you first install them. I would consider them a one-time use item. They will probably perform for years to come, but once you take them off they will be end-of-life.
Thabk you for your input!
I'm not sure I get the dilemma. The shields are going to cover the pipes anyway, right? The wraps won't "stick" to the pipes like they are melted on or anything, but once they get hot they will leave marks. If the marks bother you, a bit of 400 grit wet paper and it's cleaned up. Personally if you're going to cover it up anyway, it should be a non-issue. BTW, it really helps to put the wrap on wet. It helps with the pliability of the wreap and is easier to get tight. If possible, it might make sense to leave the wrap under the shields if everything fits. Should help with heat management on your right leg.
Thanks again!
right on!! Thank you, yeah that makes sense. I can always leave the wraps in. I wasn’t sure if the shields would fit with the wraps on, but it’s a good option. I don’t care about the pipes, but was under the impression that they kind of melted or molded to the pipes.
Thanks again!
Thanks again!
When you do it it works best back to front. It looks better as the overlap is in the right direction that way. I did it backwards on my dirt bike and every time I brushed up against something there was a tendency to grab the wrap. Back to front is better. The wrap can have a way of quickly falling apart at the ends. On the free end (that's the end that will be loose until the very end of the process, benefits from some Super Glue or something to keep it from fraying. If it takes a while for the glue to set, just throw some baking soda on it. It will harden fairly quickly then. You will want to cut that off at the very end, but it will keep things in check until you get there. An extra set of hands can help too.
Good luck brother. Post a Pic when done for us.
