O2 sensor installed backwards Quick Fix?
Hi everybody,
I am Izral and had my 1st fltrxs a year ago.
Recently i upgraded my header and just realized that the O2 sensor was installed backwards (black is not back). Just wondering, for a quick fix can i just slot it the cable backwards temporarily by slotting the black to the grey slot and grey cable to the black slot to fix the backfire and all.
I dont have access to a proper tool to change the bung that i already installed on the header and it is a long holiday here where i live.
The O2 sensors are identical, except for the connector color. If you installed the O2 sensor with the black connector in the front pipe, then just plug that one into the grey connector under the side cover. No need to over think this. At some point, though, you will want to make it right as if you ever have it serviced, and the tech notices it, you'll have a crappy running bike.
Anyway thank you very much.
