S&S 570G cam
RE: S&S 570G cam
I ran the 570s in a 95 in twin cam in a fuel injected, 1999 Road King for over 60k miles. Compression was 9.7-1. Heads were ported and flowed, stock intake, evo exhaust valves, S&S springs, roller rockers. White Brother's 2-1 E pipe, S&S VFI computer. Make 98 HP and 108 lbft torque. I absolutely loved the performance!
Same bike is now up to 116", S&S setup. The S&S .625 cams didn't work in a bike this heavy. Believe it or not, I run woods TW6HG cams. I loose on the topend but make over 100 lbft almost off idle. The power comes on STRONG at about 2100 rpm.
RE: S&S 570G cam
Any body have the website for woods cams? Thanks for reply in advance. I have an Ultra with 113" installed, have se 203 cams in it right now. Had planned on doing a 95" and put the 203's in first, then decided to go 113'. ran out of money real fast, Also the heads are stock with maching done to fit the pistons and get compression down, Is 10-2. Any suggestions on cams for better low & midrange, Right now dyno is 95 hp/114torque. plan on having head work (bigboyz) when I install cams. Thanks againg.
RE: S&S 570G cam
ORIGINAL: TBJOSEY
If you're going to have Big Boyz do your heads, you should really get a cam recommendation from them.
Actually the 570 is a rather popular cam. Works really well with the very inexpensive (these days) SE performance heads and flat top pistons. Makes for a 100+ lbs/ft of torque. Very good low and mid range, and with a little bit of head cleanup and valve grind can make some surprising HP as well.
zigz
zigz
We use them with oustanding results.
Just completed a 88"er that we installed an S&S 4 3/8" crank, bored the cylinders to 107".
S&S G carb w/Thunderjet/.570's/D&D Fatcat/our heads/10.0 cr.
On our dyno it went off at 118 plus hp/122 ft/lbs, SAE.
The measured, or also refered to as actual, was 122/126.
Smoooooooooth, broad power, that the client was VERY impressed with.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
