Sponsored by: Jekill and Hyde
SE 51MM Carb.
Old 12-11-2007, 12:18 PM
FXDWG103JP's Avatar
FXDWG103JP
FXDWG103JP is offline
2nd Gear
Default SE 51MM Carb.
Does anyone know anything about the Screaming Eagle 51 MM carb and intake, I mean from a performance stand point. Good, bad or what.
Old 12-11-2007, 01:15 PM
billgutski's Avatar
billgutski
billgutski is offline
Default RE: SE 51MM Carb.
Bad idea. Still has lag in throttle response like stock carb. If your gonna drop the dough, definitely go with the 45mm mikuni and se intake. more bang for your buck for sure!
Old 12-11-2007, 01:17 PM
GLHD's Avatar
GLHD
GLHD is offline
first off what size motor is it going on... that carb comes stock when you order a jims 120 so watch what size your motor is .. the one that we have done it works out very well on that motor.. all 3 of the bike where about 137hp and 145tq all in baggers with 2-1 pipe..
Old 12-11-2007, 01:18 PM
GLHD's Avatar
GLHD
GLHD is offline
42 with se intake also works good
Old 12-13-2007, 01:42 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
We've used 'em on 95" builds. Work very, very well when used correctly.
One we did was for an employee at a local dealership. It ripped 123 hp and 116 ft/lbs. That dealership no longer has "dyno gypsys" setting up in their parking lot to show off their "expertise".
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Old 12-13-2007, 06:09 PM
HDWRENCH's Avatar
HDWRENCH
HDWRENCH is offline
I like the 51 cv carb provided it is used in a correct build. The carb is for a larger style engine. Now that does not mean that you cannot use it on a smaller engine. If the engine is a hot 95 and past builds like it show that the package wants a larger carb then use it.
I like the fact that the carb is a cv and is user friendly, and jets nicely. There are other carbs, MIKS, S&S, PSI,Weber, etc. All have pros and cons. Over all the cv carb is a great unit for street use. We have installed them on many a engine. The smallest that we have use it on is a 103. Again that is not to say that you could not use it on a 80 inch evo. That is based on the build.
Old 12-13-2007, 07:56 PM
nick@nite's Avatar
nick@nite
nick@nite is offline
I have one on my dyna, no probelms at all runs great and easy to work on. Yes its fast and no you ride it.
Old 12-28-2007, 01:21 PM
FXDWG103JP's Avatar
FXDWG103JP
2nd Gear
Thanks guys,
I have it on my 103 CI motor with the HTTC pistons and ported heads with Woods cams. Seems to work ok for me but it's my first HD, started as a low rider has ended up as a wide glide so now I call it my LOW GLIDE. Tried to post some pics but they were to big or something. Ain't real savy on this puter stuff.
Oh it turned 118 HP @ 124 FT/LB on the dyno. Don't know if that's good or bad. Man I love this forum, but it seems to interfere with my work u no
eazzye
10-10-2012 11:17 AM
1st HD
02-16-2009 08:50 AM
FlyinJ
10-22-2008 06:13 PM
Tubz
12-10-2006 05:57 PM
Canuck HD
10-21-2006 01:40 AM
Quick Reply: SE 51MM Carb.
