Harley Davidson Forums
Harley Davidson Forums (https://www.hdforums.com/forum/)
-   Exhaust System Topics (https://www.hdforums.com/forum/exhaust-system-topics-57/)
-   -   Can't start bike after sitting for 2 years (https://www.hdforums.com/forum/exhaust-system-topics/237520-cant-start-bike-after-sitting-for-2-years.html)
Marko200 May 24, 2008 12:09 PM
I haven't started my bike in 2 years. Put a new battery in turns over fine, I suspect that the gas of the carb has some issues (I'm not that mechanical). What can I do to try and get my bike started? Any advice is appeciated.
Mark
Doc 1 May 24, 2008 12:40 PM
RE: Can't start bike after sitting for 2 years
Carb jets are sure to be clogged and gummed up...the carb needs to come apart and cleaned. If your not mechanical gifted I'd take it to some one who is.
themensh May 24, 2008 03:17 PM
Did you drain the gas tank off all the old fuel?
Change fuel filter? Make sure battery was good/charged?
I would refill the tank w/fresh fuel (and maybe some seafoam or MMO).
Shoot some starter fluid in the carb and hit the starter.....!!!!!
Now, if you didn't get at least a "POP".......your carb could be
clogged/gummed.........or no spark to the plugs. Check for spark.
(I hate troubleshooting....)
Sharknose May 24, 2008 08:51 PM
If you're not that mechanical your best bet is to take it to somebody who is. As the others have said, your problems are probably connected to letting gas sit in the fuel system. They'll have you up and running in no time.
© 2026 MH Sub I, LLC dba Internet Brands
